Hi Fellas,
I'm having a similar issue with a 55 2-door sedan i just bought. The handles were actually glued on. Lol. I have scraped off the glue and am figuring out what exactly the issues are. In any case, they do not have the plastic piece shown on SEE's post or on
Ecklar's site. Did originals have this piece? Mine do not have them. Or, are they only on repos? I'm wondering if this missing piece is part of the reason my handles keep falling off.
Glued on? Sounds like something I would have done in the 70's. 😀
As Bamanomad said, the "washers" were on the cars originally and protected the door panels . Thin plastic, the originals became brittle and fell off over time. They don't affect the way the handles work or fit.
The window handles cause a lot of problems but if they are done properly will work as they should. Got a 4 door wagon so I had lots of practice.
Start with the window channels and the scissor lift first. If the glass doesn't move up and down smoothly through the entire range of motion, fix that first. The less torque needed to raise and lower the glass the better.
The regulators need to be clean and lubed also. I know, more work than you wanted to do but the more torque it takes to move the window the more likely the handle will fail.
Then clean the regulator spindle. The teeth need to be clean. Some of mine had several layers of overspray on them and would not allow the handle to sit deep enough for full contact of the teeth surface. I also took some material off the face of the spindle as mentioned above. Easy does it, just do a little at a time and test fit. You will get good at removing and replacing the spring clip.
The groove that the spring clip sits in needs to be clean too as rossd found out on his regulator spindle.
The deeper the handle can sit on the spindle (to a point) the better.
It pays to have the right tools. I work with springhooks on my day job that make removing and replacing the spring clip easy.
A hook on one end for removal and a "pusher" on the other end for sliding the spring back on. Once you get the hang of it they are easy to take off and put back on.
After 60 years, some spindles will be worn out and won't work no matter what you do to them.
The vent windows are the same concept just a shorter handle.
Good luck and remember, it's supposed to be fun restoring an old car!👍
