Alternator Wiring Size
17K views 18 replies 9 participants last post by  Mikec81
The voltage drop plays a factor as well, as far as the PCM goes. The PCM will need at least 12v to run. Any less and it will shut off.
In a retrofit like this, the general recommendation is to wire the PCM directly to a battery feed, not a charging circuit/alternator feed.
Charlie
