This issue started on my 55 210 with just a burned out tail light. I changed the tail lights and they both don't work. Neither does the License plate lights. I've checked the connections and changed the fuses in the entire car. Twice I have managed to get the turn signals to work, only to have them fail again. I've run a wire to test from the battery, which is located in the trunk, and the turn signals did function once this way. Once again with the bulbs installed on a second attempt they worked, but eventually failed.
I have new pig tail connectors on order. I have scrubbed every connection clean and tested. I've tried all of this repeatedly. Anyone have any ideas?
