just wondering what everyones experience is for daily drivers and weekend warriors?
No system. Bought a factory engine with the TBI unit on it. Hundreds sitting in salvage cars, easy for the picking.do you have link to the system?
I agree with your assessment of the owner, but I thought it was only me as I asked a question while I was installing the wiring and did not go back to the instructions before calling him. He does not seem to want to deal that much with customers after you bought the system. I also tried to contact dunne-rite about the fuse/ relay panel and left a message but so far no return call. I still like the system but not the after sale service, good day.I put a Mass Flo on a ZZ 383. I had trouble with it from the start. The owner was not much help and liked to talk down to me as if I was stupid. I had to adjust the TPS because it was out of whack. I have issues running at lower RPM (2,000 to 2,500) and what I was told is that engine is not designed to run at the lower RPM so the EFI system will not work properly. I mentioned to him I had the same engine trans and rear combo in another car and had an Edelbrock Pro Flo on it. Told him it ran great. HE said that with the Pro Flo I was able to trick the EFI unit by tuning it richer / leaner at certain parameters. When I mentioned the ProFlo might be a better choice because there was some latitude in tuning, he said the way to get his system to perform better would be to disconnect the O2 sensors and run it like that. I am not at all impressed with the unit or the customer no service. The unit is supposed to be a self learner, but this one is a slow learner that belongs on a short bus....
