Thank you
First, I'd like to thank everyone for their continued responses. I really do appreciate everyones time. effort and suggestions. I received many more then I thought I would. Definitely alot to think about. What a great group of folks. Thank you very much, one and all.
Re. cross steering, I originally had it this way with a 14" fabricated pitman arm to be able to connect with the center link and then to the passenger side steering arm. I did it this way because of the oil pan being in the way big time and from what I read, it would give the least amount of bump steer. Someone said it would steer like a Mack truck and they didn't lie. It also gave me a severe case of death wobble at about 40 mph. So I changed it to traditional steering. I might add that I also looked at some different configurations of oil pans, but just don't know how I could ever make them work. The motor sits forward maybe 2" which doesn't help with steering alignment.
With the traditional steering, I went with a stock pitman arm, used a tierod end to connect to the driverside steering arm which is mounted on top of the spindle. The steering arm, as did the rest of the straight axle parts, came from Speedway as a kit. Part of the steering arm was fabricated to be able to reach, height and length wise, the tierod end. The steering arm is 3/8" thick and I used 1/2" flat steel for what I needed additionally to make it work. I did the measuring but I had it professionally welded. It does have a gusset welded in. I don't believe this is flexing, but I will certainly check into it.
I was out in the garage the better part of the day, just kind of looking things over. I took off the driver side wheel to get some better pics of what I mentioned in this tread. I will post them later this evening. Not sure why, but I gave a tug on the tierod end. This was kind of loose/sloppy. At first, I thought it was maybe the Heim hardware that was allowing this. A few more tugs and I saw that the steering arm attached to the spindle was loose. OMG. I could actually slide this a bit. Here I go again, but I could have sworn that I had all this tight. I don't have a clue as to how it loosened but it did. Tightened this arm and also the bottom one which also required some attention. Went to the other side and everything was good there.
I know that the steering has some issues, but not having the simple,
basics done proper, only adds to my problems. I'm going to go over all the nuts/bolts again, change the gearbox and try to reduce the caster. A friend is using my lift, so it's back to my roots: floor jack and cardboard.
As I mentioned previously, I will post some additional pics this evening. Kindly take a look. Maybe something additional will appear. Again, many thanx, Carmine.
