I have a fresh (150 miles on it) SBC 350 ci 30 over with a Comp Cam 490 lift cam, Edelbrock E street heads, Performer RPM intake, Holley 750 vac secondary carb, the motor has recently started popping when i rev the engine driving or while in the garage. Sounds like it is popping up the carb. At first i thought it was an exhaust leak but it sounds like a sharp popping when i hit the throttle. Any one seen this before or any idea what to check, vacuum is 14-15 at idle??
:gba:
:gba:
