I found this while researching info on late model swaps for our 55-57's.
Measurement
Ford Explorer 8.8-Inch
Width between wheel mounting surfaces 59.75"
Pinion offset to right of center 2-3/16"
Pinion length, tube center to U-joint center 11-5/8"
Pinion height, U-joint center below tube center 1-7/8"
Bottom of diff housing below tube center 5-7/8"
Disc brake rotors 11.25 x 7/16" ('95 to '00 models)
Brake Drums 10" ('91 to '94 models)
Drum brake shoes 7.25 x 1.25" (e-brake)
Distance between spring perches (o/c) 39"
Tube diameter 3.25" (neck down to 2.75")
Axle shaft diameter 1.31" 31-spline
This info is courtesy of © 2000 - 2008 The Ranger Station - James Oaks Enterprises LLC - All Rights Reserved
'The Ranger Station' and it's logo are Service Marks of The Ranger Station owned by James Oaks Enterprises LLC
I know many are hesitant to put a Ford rear in their car, but you can pick these up for under $300 and they come with disc brakes (in most applications). I think all you have to do is swap out the perches. If I remember correctly, Josh did one of these swaps. PM him for details or he can chime in here.
Measurement
