Heater hose
1.6K views 11 replies 7 participants last post by  trifiveshawn
#1 ·
Was wondering if somone could tell me how much and what size heater hose i need for my 56, i have a busy day tomarrow and dont think ill make it to my shop to check but i will have my radiator back tomarrow evening and plan on trying to get her running...If i have all the parts i know i wont be able to wait lol :D Thanks in advance
#4 ·
If the 57 is the same I just changed a couple of mine and bought 5/8 hose, it was really, really hard to get on the heater and bypass tubes, I was thinking of maybe trying 3/4 next time if there is one. I soaked the hose ends in almost boiling water for a bit and that helps.
#6 ·
What I do is use a flexible tape measure or something else that you can measure and run it as close to where you want the hoses to go, then I always add some to it just to make sure I have plenty.
Don't forget the hose clamps:rolleyes:
#10 ·
Although there is a rubber lubricant you can buy, I use dishwashing liquid on the nipples of the heater and the engine and put a small amount inside the ends of the hose so it will slip on easily. The soap can quickly be rinsed harmlessly away. Makes the job much easier and goes a lot faster.
Don
