I could use some help or advice here
What I have going on is a cpp drop spindle and I'm using a willwood
Disk brake kit
The rotor will not fit the drop spindle. The rear seal
Measured at 2.00 inches on the drop cpp spindle
While the stock spindle measured in .125 smaller
The seal that is in the will wood rotor does not obviously fit that 2.00
Am I using the wrong brakes or the wrong spindles
I am thinking the wrong spindle since the willwood rotor is
Fitting the stock spindle
If I'm using the wrong spindle can any one advise me which is the correct spindle to use. Possibly the heidts?
Disk brake kit
