I watched the autogeek video tonight. They were using DA polishers. Can I use my DA sander with a polishing pad?
What is the RIGHT pad and polish?I use the flex 3401. Fantastic polishing machine. With the right pad and polish it made my single stage paint really come alive.
:After confirming what I already knew with some pros. the answer would be not a good idea.Reason being that air powered tools generally dont give you the RPM`S needed VRS electric DA`S and sometimes moisture spits out of the sander.I hope this helps or you can post the question on autogeekonline.net for a more detailed answer.:anim_25:I watched the autogeek video tonight. They were using DA polishers. Can I use my DA sander with a polishing pad?
There is no real general rule of thumb on this as it varies between detailers and condition of paint.One rule of thumb for the amateurs is to start with the least abrasive products first.See my latest link to give you an idea.What is the RIGHT pad and polish?
In my case, I wanted to remove light surface scratches and swirls. The pads I use are from Lake Country CCS.They have varying degree of cutting power. As the previous poster says, the rule of thumb is start with the least abrasive possible. If it doesn’t do the trick, then move up to a more aggressive pad. Also work in small sections at a time and stop often to check out the results. It is time consuming but well worth it.What is the RIGHT pad and polish?
