I am installing new AC in my car. I don't have the AC lines made up yet. Is it okay to install the compressor and belt and run the car without any lines attached? No power is attached to compressor.
I would hold up and wait for responses. Seems like I read to hand turn it, charge, and hand turn again before running belt.I am installing new AC in my car. I don't have the AC lines made up yet. Is it okay to install the compressor and belt and run the car without any lines attached? No power is attached to compressor.
If the system is not charged, the binary switch should not allow the compressor clutch to engage, but in case it's not wired correctly, it's best to have the compressor wire disconnected, as mentioned.As long as you have no electric connection to the clutch wire the clutch is just freewheeling. I see no problem.
