belairbob1957
· Registered
Discussion starter · #1 ·
Hi to all
Posting a new thread due to change of plan, i have decided to stick with the straight six is there any options to gain improved performance.
I have rebuilt the engine all the usual stocks parts, engine runs on pertronix electronic ignition and a single barrel rochester carb it runs fine one thing i did think about was the exhaust system on it is standard is there anything i can do with this maybe to improve performance and can i achieve a better sound (i know it sounds daft but would like a nice burble sound).
Hi to all
A guy I know put a "wye" in the pipe on his rebuilt 235 and put dual flowmasters on.....sounds awsome.....Bill
235
had a55 hardtop back in 67 had 261 pontiac 6 cyl with isky cam, split manifold , dual exhaust,and 2 2 barrels. i also had 3 spd overdrive that i had hooked up as a 6 spd...did a post on that a while ago.i was very happy with it , lots of torque a few small blocks in town were not so impressed , if you know what i mean ... Fred
You could always go with a turbo on it, 5-6 lbs of boost should provide a good amount of power increase without having to beef up the engine as long as you don't over rev it and run 92-93 octane gas maybe less if you do some form of charge cooling ( not a bad idea on any turbo setup ). And then you would have a engine setup thats probably going to be unique from all your local tri five owners :)
Also you could put a perfomance cam and the fenton headers, offy intake manifold 2x1 or single 4bbl
if you wanted the more classic hop up approaches.
Heres a link to a vendor in the Usa that carries such parts
http://www.cliffordperformance.net/...ormance.net/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=CP&Category_Code=C235
Regards, Robert
That is one nice looking engine, and there are several thing's you can do as you have already been advised in previous post's.
I think I would go for the exhaust mods first. My .02
Don't be sorry for asking question's, or for help. That is what this site is all about.
Ed :cool:
