Hi everyone. I have a 2014 Dodge Ram pickup with the hemi engine. I bought it new and have 103,000 miles on it. Recently I've noticed the odor of antifreeze that comes through the heating vents when I call for heat. It seems to only be in the beginning, but it's obviously there. I also don't think the heat gets as hot as it use to. I checked the antifreeze level, and I'll check it again, but I think it's ok. It doesn't overheat or run hot. Temp is as it's always been. Did some research on line and many point to the heater core, but don't elaborate as to how to check it out. Has any member ever had this issue?? Your thoughts on this?? Thank you very much, Carmine.
