Just to help clarify things a little. When an engine is "balanced", there are TWO balance weights that they are working with. Reciprocating weight, and rotating weight. Reciprocating weight is made up of the small end of the rod, the piston pin, and retainers if used, the piston, the piston rings, and a "nominal" amount of oil that would natually coat the parts while in use; it is the weight involved of the up and down motion of the piston assembly in the cylinder. Rotating weight is the big end of the rod, the rod bearings, the dampener, the flywheel/flexplate, and some machinists also include the clutch assembly, and again, a "nominal" amount of oil; this makes up the spinning/rotating assembly. Therefore, all the engines parts need to be separate in order for balancing to be done. Pistons, already on rods, can't be balanced, nor can the small end of the rods be balanced with the piston hung on it. First all the reciprocating parts are weight matched. Then the rotating weight is computed, and a bob weight is arrived at. Once the bob weight is arrived at, the crankshaft can then be balanced by removing or adding weight to the crankshaft balance weights as necessary to arrive at the bob weight/balance weight figures. This is done on a machine that spins the crank and bob weights, and has an attached drill used to to lighten the cranks balance weights as needed. Adding weight is rare, and more involved, and very doubtful for a street engine. Of course a stobe light is used to pin point where weight needs to be removed/added. Overbalancing has already been discussed, and is primarily for race type engines. Factory balance is an "in-the-ball park" sort of deal. Even replacement pistons, including those in oversizes, are again, an "in-the-ball park" weight of factory pistons, so as not to have to redo the factory balance, but factory balance is far inferior to a machinst balancing all the engines parts/components. It is amazingly cheap what balancing costs relative to the time it takes, and the equipment used. That's a basic, simplified explanation.......I'm not a machinist, I'm not a DR., and I don't play one on T.V.; I'm a retired X-Ray Tech., and I appreciate what my machinist does for me. Butch/56sedandelivery.
