Opinions wanted - transmission or gears?
1 reading
1.6K views 13 replies 10 participants last post by  bigblock261
#1 ·
Our `56 wagon has a 283, TH350 and 3:36 gears. Most of the driving we get to do with this car is around twon, so that set-up works fine. But, if I want to go out of town to an event, show, cruise etc, then I am running 3000 rpm to maintain 62 mph. Because of my limited "top speed" I hate to drive any of the freeways. I have wanted to drop in a 700R4 for several years, but frankly, I can't afford that kind of dough right now. Someone suggested to me that I might want to change gears to 3:08 or even higher. This would certainly be more financially do-able, but what would I gain and what would I lose?
#3 ·
Changing from a 3.36 to a 3.08 will drop your RPM at 62 MPH from 2567 RPM to 2353 RPM assuming a 28" tire. ....http://www.ringpinion.com/Calculators/Calc_RPM.aspx If your are actually taching more than that, the torque converter or transmission may be slipping excessively.
Changing to a 700R4 will drop the RPM at 62 to 1750 RPM with the 3.36.
#9 ·
Very good info here, and thank you for this link. I just measured the rear tires at 25" (235/60/15) and using the 62 mph (which is a "guess-timate" because the speedo is not 100% accurate), I get an rpm of 2875. With an AOD that rpm would be 1960 or 2230 at 70 mph. Right where I want to be.
I also liked bigblock261's comment about the spread between 1st & 2nd being more friendly to a smaller engine. Not sure why, but 200R4's are hard to find and not very well-liked in our area. I have spoken with several self-proclaimed transmission gurus about the 200 as a lower cost alternative to the 700 and none of them have much good to say about the 200. Any idea why? It seems that many folks here at Tri-Five have and like the 200.
#4 ·
Small motor, tall gear.
The 283 is a fine motor, but a bit low on torque for a 3.08 rear gear. The cruise rpm will be lower, but I think the car will be somewhat anemic in all three gears.
As you have stated, you need overdrive. TH 700-R4, or TH 200-4R if you want to keep your present driveshaft and save a few bucks. With the 200, your transmission crossmember will have to be moved back a bit. The ratio spread between low and second gear is friendlier to a smaller motor with the 200.
Just my humble opinion.
#5 ·
Wouldn't aerodynamics/weight play a role in this calculation? With a 26" tall tire then you're a little closer to the 3000rpm mark, about 2700 or so. I would save up and go with the 700r4, but until then if your 283 is healthy it should cruise at 3000-3200 all day long.
#6 ·
Weight and aerodynamics has nothing to do with the nymber of revolutions the engine makes when the tire goes around once. They are directly coupled together with a manual transmission and the calculator allows for some slippage of an automatic torque converter.
#8 ·
I say put a 200R4 in it.
Change rear gears may be cheaper but so much better to go with the OD. Save up and you will be much happier in the long run.
#10 · (Edited)
I have an original 56 convertible with 265 P/P and P/G trans. I swapped out the 3.55 rear for a 3.08 and gained 10 MPH @ 60, Not sure of the RPM but it made it safer to run at highway speed without really winding the engine up.
I also have a 355, 700R and 3.36 gears in my 55 wagon and it also works great. Obviously the O.D. trans would reduce your RPM more but either will work for you. :anim_25:
#12 · (Edited)
The 3.08 gears are the answer as long as you're not a red-light bandit . You'll cruise @ way lower
RPM's , probably about 2500 @ 62 mph , and save a ton of fuel . The overdrive trans would be a great option for a next expense though ; then you could stick your 3.30 gearset back in . Bob
#13 ·
Dollar for dollar , you could make your own overdrive setup with a pair of 235-75R15 rear tires , a much larger circumference (taller) tire , if you didn't mind the rake . I really can't see a 283 doing much damage to a 200R trans . They're not popular with the big-motor guys because they have much smaller clutches , and won't take the abuse , but GM built them and they're not junk . You could probably find a trans kit for one if you did the homework too . Good luck and have fun . Bob
