I'm trying to trim a replacement quarter panel and need to know how you guy's get a tight enough fit for butt welding ?.Do you over lay the new and old and cut with a abrasive wheel, or do you scribe lines and cut to match, then trim as needed ?Trying to align B pillar door jamb and wheel well lip has proven difficult. Any tips are greatly appreciated.
Attached are pictures of the replacement panel, the bends at the B pillar are close to a 1/4" where as the factory radius is around 1/8", any suggestions on how to fix this miss match.
Thanks in advance.
Russ
Thanks in advance.
Russ
