I've built a number of brand new brake systems, and never had any time or trouble involved in bleeding them. I start by bench bleeding the master before it's installed. But using the bench bleed hose kits you can disconnect the output lines and do the same thing on the car also.
Once the master is bled I go to the furthest wheel from the master, and put my vacuum bleeder on the bleed screw. Suck the line until I get fluid with no bubbles, and then move to the other rear wheel. Then furthest front wheel, and finally closest front wheel.
After that everything is good to drive it. Takes less than an hour and often less than a half hour.
