my double-hump heads, AC r45`s were it them. wandering if i should keep using them, or anyone has a better idea? thanx. 355, comp cams #292 cam, 65o carb. thanx again.:confused0006:
NO, TS means "tapered seat" and they would be a 5/8 hex instead of the 13/16 hex the R45's with the sealing rings are. I have found the Autolite #295 works extremely well. They are the only plug that crosses to the AC R46 which has been discontinued for a while now.so i take it, TS means extended tip? ya know how that helps? thanx.
Heres a link on spark plugs in fomy double-hump heads, AC r45`s were it them. wandering if i should keep using them, or anyone has a better idea? thanx. 355, comp cams #292 cam, 65o carb. thanx again.:confused0006:
