Thermostatic fan switch - 195 vs 185
14K views 3 replies 3 participants last post by  kbuhagiar
The fans will probably never shut off with a 185 switch. That's what I don't like about temp switches. There is too much difference between on and back off (usually 15 degrees). I like the Dakota fan controller because you can program the on/off temps as close as 3 degrees. As you noticed, with a temp switch, the temp is always swinging up and down between 195 and 180.
