I have a 57 BelAir coupe. The car has had 1 repaint many years ago. Other tha n a small fender pucker from a lit bumper hit, there appears to have never been any body damage.
The out side of my original trunk lid was perfect but the inner structure had quite a bit of rust thru from condensation.
I bought a new Golden Star trunk lid.
The gaps on the edges are much tighter (barely 1/8" on left and right) than other trifives that I have seen (doesn't matter which trunk lid I use, the Golden Star appears to be an accurate copy).
The real problem is the right rear vertical section tightens to less than 1/16". Again, there appears to have never been any body damage.
I hate to grind the edge of the new trunk lid and reweld to get the gap right (I fear the heat might put waves in the largely flat vertical section).
I guess my only choice is to cut the body lip (quarter panel) with and abrasive wheel and bump out about 1/16" and reweld and grind a radius.
However, the trunk flexes a fair amount and I fear the paint will get chipped pretty soon with such a tight (1/8") side gap.
Anyone have suggestions and does anyone else have this tight of side gap? (my friends 57 210 is about 3/16" side gap):flag6:
