If you need to get electrical or audio wires for your windows, door locks or spreakers to your doors without seeing them, I can custom make your two door hinges to hide these wires.
I will custom make your hinges with a passage way thru the bottom of your hinges that wires can pass thru without detection. This passage should accomodate all your wiring needs. This is a very labor intensive process where I cut off approximately 1/2 inch of the bottom of a portion of each hinge. I then weld back steel sides and bottom to make the hinge look as close to original as possible - except it now has a tunnel path for wires to pass thru to the doors. This custom process costs $150.00 to do a pair of your hinges, plus shipping - Priortiy mail flat rate boxes $20.00 with insurance. Hinges must be in good condition to start and include the boxes. I will make the hinges, sandblast, prime, run fish wires and return them to you ready to paint. To do a four door (four hinges), $275.00 plus return shipping. If you want new (recommend to do) hinge pins and bushings, add an additional $7.50 per front door hinge. Most people do the bottom hinge, but can do either top or bottom as they are the same.
Below are some pics of completed hinges. The bottom opening passageway is on the bottom of the hinge.
Thank you and if you want more information - email.
:gba:
Fuzz
