Can anyone help me with the proper amount of lifter preload? Ive found anywhere from .060-.100. Just looking for the proper spec.
Are you using stock rockers or adjustable units and getting your pushrod length for a different cam? Ideally I would run .080-.090.Can anyone help me with the proper amount of lifter preload? Ive found anywhere from .060-.100. Just looking for the proper spec.
The rockers are self adjusting install and torque preload is set, but you will need to verify push rod length as the cam isn't stock to verify preload.Stock rockers with a tick performance stage 1 turbo cam
Ahh ok yeah the LS7/LS3 lifters are same. Install checker torque rocker arms to 22fl/ft. adjust PR checker to set preload .80-90, remove rod checker, and measure it. Thats the push rod length you need. When you install them and torque rocker arms it will be set to what you spec'edI have a 5.3 with ls7 lifters. I have a pushrod length checker. I need to know the preload to add after i check length. Stock 1.7 rocker arms from 5.3
No not really. One reason to check it. The stock truck push rods are 7.4'' and the cam has a smaller base I assume, than the stock truck cam so no surprise really.Does this seem weird?
Smaller than what the truck cam? There are alot of factors again one reason to measure and know what you need. Did you measure with an old head gasket or just calculate it? The MLS are little thicker than graphite.Well its not supposed to have a smaller base circle. Are the mls gaskets thinner than the graphite gaskets?
that is fine and 7.350 is a common aftermarket pushrod size for ls engines .I measured with the new heads and mls gaskets installed with heads torqued down. Just worried about being off on my measurement.
I put the length checker in and turned the motor over til the checker was at the bottom of the travel and wasnt moving up or down when i turned the motor over. I then torqued down the rocker and checked for lash. At 7.265 there was a little bit. At 7.270 the rocker was snug. So plus.08 is 7.350. Was this correct way to check? If im a little short, worst case the motor will be noisy at start up and i can go longer?
most hotter cams with modern grinds have some valve-train noise due to the steep ramp angle on the roller cams. I would not go longer on the pushrods. just learn to live with the noise. my 4.8l with .604 lift is the same way. sounds like a singer sewing machine. excessive spring pressure exacerbates the issue too.So i got the car fired up and the valve train knocked and clicked for a few min then got quieter but it still sounds like a sewing machine. Im wondering if i shouldnt get the stock 7.400 pushrods and run them? Would it hurt to put the stock ones in to do a test? I have a .610 lift cam amd dual valve springs.
