After reading these forums and watching videos, I think that I have the wiring for turn signals down but please check my sanity
! I have a 56 3100 with an ignition switch and steering column from a 65 Chevy van. The ignition switch has 5 connections on the rear - D-R, ACC, BAT, IGN, and GND. The current wiring is a rat's nest so there's no way to make heads or tails of it, and I don't want to rip it all out and rewire yet. That's a job for another year.
My plan = Wire the flasher from the fuse block using a connection that's only on when the ignition is in the ACC position. Then wire the new turn signal switch as normal (flasher to purple wire for turn signal switch, white from brake pedal switch, other connections out to lights/turn signals). Should work yes?
Also, the turn signal switch has a brown wire for 4 way flashers, and a button for it on the steering column. I don't know how this could be connected so that the 3100 has four way flashers (hazard lights). What am I missing?
