421 Torque Monster
13K views 9 replies 8 participants last post by  CNC BLOCKS
I tell people if your going to build a 400 or 406 bump up to the 421 for a street build its the way to go. Spent the morning on the dyno with Frank Carey. This is the 421 I built, Pump gas HYD roller he wanted a torque monster and that's what he got, I used the AFR 195 heads, Best Torque number 568 @4200 RPM Best HP number was 524 at 5500 RPM. This engine made the best HP & torque numbers with only 30 degrees of total timing. At 3400 RPM there was a dyno sheet that showed 550 Torque. Also a big shout out to Johnson Lifters the valve train was quiet as always, No need for the Snake oil and only needed a 1/4 turn down from zero lash. No need to break in lifters LOL.
Dart SHP block all machined in house
Mahle Flat top piston
3.875 stroke 4340 crank
Scat I Beam 6.0 - 7/16 bolts ARP 2000 series
195 AFR heads 75 cc chambers
Air Gap intake
GM Dist
Scott plug wires
Cam 238/242 on 108 lobe sep, .573 lift Step nose cam
750 Quick fuel carb
Timing set Cloyes Hex-A-Just
Lifters Johnson 2110-R
Champ 8 quart oil pan
Oil Pump 10552
Scorpion 1.5 rockers
326957
326958
326959
#7 ·
I looked up the price on a SHP block for an SBC, it's about $1600. A new GM block that needs way more work to use it is $1150. And the Dart block is undoubtedly better in all details. Price does not seem out of line.
The days of using a junkyard block to build a decent engine have been over for a long time. And really never existed for a big bore SBC.
#9 ·
CNC,
This is a very timely thread as I am considering a very similar engine for my 1966 Nova. It currently has a 406 with a spun main bearing. Turns out the screen broke off the end of the Milodon pick up tube. I had the motor built by a local performance shop, its runs pretty good but this is the second catastrophic failure...Needless to say it is getting expensive and I need to make a change.
I was researching crate motors using the Dart SHP block and noticed 421, 427 and 434 cubic inch engines being built. I have heard of issues with the 434 but that was in the 400 blocks. What is the pros and cons to these builds.
As mentioned, this engine would be for a 1966 nova that is 99% "spirited" street driven and very rarely taken to the track. I am looking for 550hp range. The car currently is a 4 speed but i will be making the change to an automatic at the same time. It has a factory 12 bolt (c-clips eliminated) with a 3.55 gear.
Any information you have would be appreciated
Thank you
Ron
#10 ·
CNC,
Thank you
Ron
Ron
The problem with 4.0 stroke is cam to rod clearance. When reducing to small base circle cam you increase lifter pressure angle which in not a good thing. That's why I stick to a 3.875 stroke, Even then you do have to run a reduced B/C cams. My 421's with a solid roller I can get away with a .990 B/C and use a .420 lobe, On the engine I posted I used a 1.050 B/C
You should be able to have your local shop look over one of these and have them build it for you.
Here is a 427 I build using a 3.875 stroke with a 4.185 bore custom pistons is the only draw back
421 solid roller 220 Heads
Good Luck which ever way you go.
