I cut out the outer rocker on my -56 2 door hdtp the other day because the fabbed up outer rocker was not fitting well at the door and front fender.
Turns out that the inner rockers are fabricated as well. Some parts of it was rusted out due to some custom drainage pipes added, but the rest of it was solid.
Anyhow when I got the new inner rocker in place the lower lip did not match the inner rocker. No way I can bend it to fit either, the distance is some places more than 14mm, more than half an inch.
So now I wonder if I am going to cut out the inner rockers and put on new ones but since the problem is that the inner rocker is too far away from the outer I suspect all 5 body mounts have to be extended as well.
Good advice much appreciated....
