New motor pre-start. Priming oil pump with single shaft on drill, it is going as fast as it can. 40 lbs on gauge , nothing on oil to rockers. Open for suggestions to remedy this, or not worry about it, start motor and watch oil gauge? Thanks
been using one for many years----what can that tool do that a modified distributor can't? sits in hole, turns oil pump shaft same as your distributor when you get engine installed and fire it up.I thought everyone cut up distributors to build primer tools.
You are 100% correct, the "tool' I made was cutting the top section off an old HEI, I've seen guys just pull the shaft out and use it on a drill, that will "not" work properly.been using one for many years----what can that tool do that a modified distributor can't? sits in hole, turns oil pump shaft same as your distributor when you get engine installed and fire it up.
Correct. You need a tool with a cylindrical part attached that mimics the distributor housing, which is necessary to fed the oil up into the right side valve train.If you are using something like this you won't get oil to the valve train.
Since I'm not a car junkie, (not by choice), it was a lot easier and cheaper to buy the tool on ebay.I thought everyone cut up distributors to build primer tools.
mine's been built and installed for 3 months now but never fired yet. Using my gearless distributor and dewalt half inch drill got 65 lbs pressure and oil on all rockers in about 3 minutes. distributor still out so will prime again before firing it up hopefully within the next month.I use a corded 1/2" drill that turns about 300 -400 rpm loaded when priming a Melling high volume oil pump using the proper priming tool. It takes a while to get oil into the upper valve train of a BBC. (haven't done an SBC)
Why do you have a high volume pump?I use a corded 1/2" drill that turns about 300 -400 rpm loaded when priming a Melling high volume oil pump using the proper priming tool. It takes a while to get oil into the upper valve train of a BBC. (haven't done an SBC)
Not me. My priming tool was $17 at Summit new, and not worth the work, or losing a good distributor.I thought everyone cut up distributors to build primer tools.
There's high volume, and high pressure oil pumps, and they aren't the same. I always use high volume oil pumps on new builds, and like them. But I don't use high pressure oil pumps as when the engine is cold the pressures can go high enough to blow out seals in places.427 set up loose for racing and machine shop insisted on a high volume pump.
