I am looking for the cheapest and best way to put disc brakes on my '57. I know that I can order from the vendors, but was wondering if there might be a bolt on situation from a donor car.
i honestly think that the sellers are getting away with selling these horrible kits because there are a lot of buyers who just aren't aware of the problems that these kits will cause them ... until its too late. in all likelihood, people don't know about the wheel offset problem until after they've bought the kit and then they're saddled with something that just won't work for them. so instead of throwing the kit away and spending more money to do it right, they stick with what they've got, throw good money after bad, and end up rubbing their tires.No isues what so ever but it scraped sometimes? These kits are no good and not only because the tires rub sometimes but I am so sick of seeing beautiful tri five cars with the front wheels out flush with the fenders or even out past the fenders where they don't belong! because they can't engineer these kits properly! Yes these kits have been around and in use for a long time but not because they are good, It's because that is what the supliers are selling! Unless you do your research and find other options that are much better! But there is a place for these kits for people that just want to upgrade to disc brakes for a minimal investment and don't care about sacrificing the look of their car, and don't mind their tires rubbing the fenders sometimes. NO THANK'S!!!!
thanks to this site, i've been able to do A LOT of research before the sale, hoping that i'd be able to avoid many of the pitfalls that go with a disc brake conversion. as much homework as i've done, i'm still not sure that i'll get where i want to be -- keeping a stock looking 14" wheel/cap combination. we'll have to see how it goes.
my criteria for success won't be the same as some other peoples' -- i don't want ANY rubbing of the tires when i've got the wheels turned hard and i'm pulling into a driveway. a properly designed car shouldn't rub its tires. if my car ends up with rashes on the tires because they're rubbing, to me the tires will be shouting out to the world that i failed to do the conversion properly. i don't want that.
thanks for the advice, but no -- i won't end up keeping my drum brakes. i'm going to keep researching the topic until i find a workable solution that allows me to have car that looks like an old car but stops like a newer car. that solution will not involve using inferior brake designs that make tires rub.Since you're such a purist, keep your original drum brakes and you will be just fine.
Let's do a reality check here. ALL the kits that use the Chevelle rotor, (and that's 99% or more), will move the wheel out the same excessive amount. That is what's been used to convert to disc brakes with stock spindles for 30 years or more on 55-57s, ever since the first guy figured it out. THEY ARE ALL THE SAME if they use the Chevelle rotors and stock spindles. You may call it poor engineering - what it really is is this - taking advantage of available OEM parts to do this in a simple and inexpensive manner, even if it has shortcomings.
The only other way to do this with a stock spindle is to have a separate hub and use a rear rotor from a Transam. I do not have a clue whether an OEM hub like a 61-68 full size Chevy, or a drum brake hub from a Chevelle or early Camaro will work. Probably not, I'd guess it needs to be a custom hub.
You can also get Wilwood brakes with custom hubs.
Any separate hub kit is going to cost more than one with Chevelle rotors. Cost drives this issue. Most guys that are willing to spend that kind of money are wanting the lowering that comes from dropped spindles - so there's a small market for stock spindle setups like this.
Check your mailbox I sent a few articles your way.I am looking for the cheapest and best way to put disc brakes on my '57. I know that I can order from the vendors, but was wondering if there might be a bolt on situation from a donor car.
There will always be more people who are willing to modify than there will be who want to keep things original. That shouldn't surprise anyone. Its the easy way out and its often the cheaper way out too.Exactly, except I don't really consider the "Chevelle rotor kit" to be excessive since adjusting wheel back space is the key. But if you require OEM wheels and such then it may not be an option. I think it's absolutely wonderful that you can buy a GM rotor that fits the 55-57 spindles, bearings work, seals work, try that with a Fxrd product:confused0006: Who ever figured this out in the early 70's was quite crafty.
for what its worth there are more fellows installing non OEM wheels(like 17-20's) than orig.
if its a meaningful comparison there would be no argument whatsoever and the search for information would finally be over. but if it turns out to be a meaningless comparison of apples to oranges, then the search for knowledge will have to continue. continuing the search for the right answer is not arguing.There is no reason to think that a 14" x 6" wheel won't clear the caliper - it will. What might not clear is the upper ball joint.
You would be welcome to come over and demo the caliper clearance on my 67 Nova. But it's too darn hot for me to do it today. You'd probably just argue with that too.
14x7 @ 4.5" BSOK. 4.5" BS on a 14" wheel is a no go. Diameter is fine, no problem with ball joints, the front edge of the caliper sits against the wheel.
14x7 @ 4.25" BSI placed a 1/4" spacer, better but still rubs. At 4" BS the caliper just barely rubs at the end of the mounting pins. They could be ground, slightly-probably 1/16" to clear.
Would it be a viable option to try a 3-7/8" BS wheel, and if there wasn't enough clearance, add a 1/8" spacer to produce the equivalent of a 3-3/4" BS? I was thinking that doing it that way would give me two options, while going with a 3-3/4 would only give me one option.I would say 3 7/8" BS is max for 14" rally wheel(I would play it safe with 3.75" BS). This is Heidt's 2" drop, 10.5" rotor with big GM caliper.
Thanks -- its looking like the proper tire will be nothing larger than a 215. That would suit me fine.Im my opinion, a 14X6 disc brake wheel with 3 3/4-3 1/2" BS would work both on inside and not hit the fender on the outside, as long as no more than a 215 tire is used.
The 57 wheel and tire specs page says that the originals are a "0.560 offset x 14x5J (modified)" wheel. I have no idea what has been "modified." I'm not sure that I would want to go with a 5" rim because the spec pages for the tires I have been looking at require a minimum rim size of 5.5" and 6".Are orig 14" wheels 5" wide or 6"? If 5" then 3.5" BS would be great.
Alabama:I am looking for the cheapest and best way to put disc brakes on my '57. I know that I can order from the vendors, but was wondering if there might be a bolt on situation from a donor car.
