Are We Ready To Rumble???
1.9K views 22 replies 10 participants last post by  56ls408
They did a final test on my 1968 Pontiac OHC 6 250 Engine. They did a compression test while engine was still warm and Compression stayed at 140 with a CR=10.0:1, and then they did a leak down test on it. Leak down test was incredibly tight. Temp was allowed to creep up to 190 degrees and oil pressure held at 30 psi.
I'm not an expert at this but I think these numbers are damn good. Rochester Quadrajet was overhauled but it will need to be tuned.
Transmission not done yet. Top mechanism works great but interior needs to be completely upholstered. Disc brakes and suspension not done, and dash panel being rewired.
So engine will be wrapped up until ready for it.
Bob
youtu.be/ZwmVGCfGSjO
I have no clue what kind of timing set is on that ohc engine but I'm pretty sure that advancing the cam would make wonders.
No offense, but when I consider what I started with, I'm already working with wonders. BTW, have you ever seen or worked on one of these scarce OHC 6's? I've never seen another other than the ones I own, so I'm always willing to listen to experienced help. Your suggestion has merit, as it seems to work on other more conventional engines,
Thanks
Bob
#5 ·
No offense at all Bob and no I haven't worked on Pontiac ohc engine but yes I have seen one.
An engine is an engine and it doesn't know what is scripted on the valve cover, all I'm saing is that to me 140psi cylinder pressure in fresh build sounds pretty low.
#6 ·
Running an engine on an engine stand allows checks for leaks & not much else.
Everyone is concerned about low cranking compression we have a cart before the horse scenario here its a fresh build, take the d a m n thing out for a ride & bed the piston rings in.
One of my 13 to 1 mills only pumped 195 after the rings were bedded in on a engine dyno, it had a big cam with a lot of overlap.
#17 ·
Bob, I don't think anything in your engine is broken. All I'm trying say is that I really think that advancing the camshaft would really help. I've done that mistake and messed up timing set installation the result was that camshaft was retarded and due that cylinder pressures were really low and while the engine (350 sbc) did run and sounded good it was a dog to to say the least.
#19 · (Edited)
It's interesting no one has asked whether I'm using a domed or flat piston. I believe that due to valve travel, they used q "D" shaped .060 recess;. (see pics)
The cam that was on there looked good. It may have had the head overhauled. So they cleaned it and reinstalled it. Everything was replaced in the order it was removed.
Machinist used 1968 Pontiac specs to put it together, and mechanic used the thinnest head gasket he could find online.
#22 ·
Cam is definitely belt driven. I thought you knew that. My piston tops will maintain better compression, but I am using different pistons in each of my two engines. Ohe has a "D" type recess that may cause a lower compression than the other that has a flat top but with valve clearance notches.
#23 · (Edited)
The flat top with valve reliefs were used in the higher compression quadrajet version of the OHC six the dished version in the lower HP version.Then often with most standard replacement pistons they could be lower in the hole than the originals.Like was mentioned you could double check the cam timing which is probably set correctly.Then put miles on it & with that good of a cylinder leak down test there is nothing wrong with the rings or valve sealing.Ive had the head off of one many years ago but don't remember the circumstances.I thought they were a unique engine back then but didn't have enough cylinders or nearly enough cubic inches to be of much interest to my 20 something year old self.Having said that kind of nice to see one saved instead of made into a fake GTO.I might have elected to convert to a 4 speed though.Should be a nice car when done.
