The previous owner removed an automatic transmission and installed a floor shift 4 speed and did not use the stock Z bar mounting hardware. I believe he used new correct parts inside the cab of the car but he changed how the Z bar is mounted. He welded bar stock to the frame and installed a Z bar on that bar stock, not sure if the Z bar is for a 57 or not. I have recently installed a 1990 1 piece 350 and the T10 with aluminum bellhousing (P/N 3899621) the previous owner had in the car. I saw a kit offered by Southwest Speed (P/N 650-4634) but after calling and talking to their representative he talked me out of it, he said unless my car was completely stock not to use his kit. My question is if I purchase a clutch frame bracket with pivot ball where do I weld it to the frame to correctly start the installation of the Z bar? Are dimensions available somewhere? My second question is, since I don't have a stock 57 bellhousing how do I mount the pivot ball on the motor side, do I use the hole above the oil filter? I understand I will also need some additional parts felt washers, adjusting rod, ( I did not use a 57 clutch fork, but used a 69 Chevy fork) etc. I tried to use the previous owners setup but when the clutch pedal is pushed in, everything is fine, but it makes a clunking noise when the pedal is almost fully released, and I have not been able to figure out the issue so I am going to start with a correctly mounted Z bar. Any help would be greatly appreciated.
