1 - 12 of 12 Posts
Pops @ Tri-5.com
· Admin & Tech Articles
55 HT, ZZ4 w AFR's, 700R, 3.55 Posi
When a Trifive was just another daily driver
Discussion starter · #3 ·
Back in the day you hardly took a second look :) A bit different now !!!
Yup...Had Trifives as daily drivers, when I first started driving in the early '60's
Unfortunately, I do not have a picture of everything connected together.
But I have a towbar made specifically to connect to the front of the 56 Vette. Several years ago, I connected the Corvette to the Chevelle and had the little trailer connected to the Corvette and flat towed them with the Chevelle.
I guess what I should do is go connect the towbar to the Corvette and hook it to the Chevelle and take a picture for that 1000 word worth of proof!
This is my tow bar setup for flat towing the Corvette
Unbolt the bumperettes (4 bolts) from the front cross member.
Bolt the fabricated hitch in place where the bumperettes were bolted.
Connect the tow bar to the hitch and connect to the trailer hitch on the Chevelle.
Pretty quick and easy for one driver to take 2 cars to a show.
In 1979-1981 while in college I drove my first Nomad back and forth from San Antonio, TX to Southeast KS (650 miles one way) for semester break and holidays - along with everywhere else I needed to go. It was the only car I had.
If you look closely you can see the ball hitch I mounted on the back - I pulled a small enclosed trailer with all my belongings back and forth for summer break.
tom's towbar looks like the one I made in 1971 to tow my Henry J back and forth... :) which I've still got somewhere.. :)
I tow with my 57 all the time. I do not own a cell phone and never have but it seems i can't hide anywhere either.
Someone seen the wife and I returning from a day out fishing.
Dragging a buddies broke Ford home for him.
Fetching a 400" pontiac powered cop car.
I use my car for deer and hog hunting also.
They fit nicely in the trunk :)
4 door cars are easier to get your fishing buddies into.
Yes my hood is propped up in the rear for more airflow through the radiator at highway speeds.
And I installed a mirror on the passenger fender so it is easier to see the boat and trailers on that side.
1 - 12 of 12 Posts
