Ran my '57 at Bristol Dragway last night
3 reading
2.5K views 34 replies 13 participants last post by  Bitchin'57
#1 · (Edited)
Made a couple of first ever passes down a dragstrip with my '57 Chevy. I aired down my Nitto drag radials to 22 lbs. With no linelock, I was able to let out some smoke from the Nittos. On the first pass, I came off the line with almost full throttle. Boy, those Nitto's hooked! My shifting was terrible, because my Holley Sniper shift light was flashing like crazy all down the track. I had it set to turn on at 6,300 rpm. I didn't know when to shift because the shift light was flashing almost constantly. I shifted into 2nd, 3rd, 4th, and accidentally popped it into neutral before pulling it back into 4th before running through the traps. ET was a 12.54. The top end MPH clock was obviously messed up.
Here's the thing about my Holley Sniper shift light. It plugs directly into my OBD II port. Problem is, my Dakota Digital gauges are already plugged in there. I purchased an OBD II splitter cable, but I found out that it can't operate two seperate things. So, what I did at the track was unplug my DD gauges, and plug in the shift light. But now I don't have a tach, so I had to trust only the shift light. Honestly, with the way that thing was working, I would have been better off without the shift light.
The second pass wasn't any better. I didn't know what was going on with the shift light, but I kept it plugged in. I short shifted 2nd and 3rd gears, even shifting into 4th to try and stay out of the damned shift light, to no avail. ET on that run was a 12.66 @ 106 mph.
I'm going back to my tuner and have him look at what the line pressures are on my trans, just to make sure they are where they need to be at WOT. And, I have to do something else with the shift light, probably buy another style that wires in.
For whatever reason, my wife didn't get a video of the first pass. Here is a video of the second pass. Sorry she didn't capture my burnout. :confused:
#2 ·
Sounds like you done good for your first time out.
What were you doing so far away from home?
#3 ·
In 50 years of drag racing I never really had much use for a shift light. Sorry, not familiar with you combo to know if mid 12s are good or bad. Offhand not bad for a streetcar on street tires. Had issues with a electronic tach causing a miss 40 some years ago, disconnected it and made the final round. Thats when I got hooked on mechanical tach's.
#8 ·
#10 ·
Personally, I would program the ecu to make it shift when you want it to at WOT, ditch the shift light and let the ecu do the work. it will be more consistent than you ever could. also, anything sniper is suspect in quality and function.
#11 ·
Hotrodg426, he doesn’t have a sniper Efi system. He has a Holley Chinese made “sniper” sheet metal manifold. It‘s probably ok unless there’s a vacuum leak or develops one. And it can’t be too bad with 470 rwhp. On the other hand it may not be a big gain if any over the plastic OEM LS3 manifold. I suspect he likes the bling of the polished aluminum over the black plastic stock manifold.
#12 ·
I was referring to the sniper efi shift light. I believe he has a dominator controller.
#19 · (Edited)
I have to say this about the tech inspection process. They were running a bracket race event this entire weekend, and Friday's test n tune that i went to was part of it. Tech inspection was a total joke. I mean, there was NO tech inspection whatsoever! The tech inspector guy sat inside a booth. I drove my car over to tech inspection, got out, walked over to him, and handed him a form that I had filled out. He asked me for my car number. I said I don't have one, its not a race car, its just a street car. He said, what number would you like? I said, I don't know, how about 57?
I signed another form, and I was done. He didn't check a damned thing on my car, or look at my helmet, or even ask me if I had a helmet. This isn't some backwoods hillbilly dragstrip out in the middle of nowhere. This is storied Thunder Valley! Even though this wasn't an NHRA sanctioned event, its still an NHRA track. I couldn't believe it.
I have to say, its convenient to live just 5 miles away from the dragstrip! If while I'm at the track, I ever forget something, a tool, a folding chair, whatever, it isn't a big deal to drive home and get it.
Nice looking facility, isn't it? Now you can see why they call it Thunder Valley, because in an actual valley! Notice how the shut down goes uphill.
#21 ·
Trust me, I will try that next time. Unfortunately, that next time will be next spring. That was the last test n tune night for the year here.
And yes, all in all, I had a good time. I'll admit I was a bit nervous leading up to the first pass. I was thinking of a thousand things that could go wrong, LOL But after I got that first pass under my belt, I felt much more comfortable on the second pass. Hey, nothing broke, the car hooked and drove straight with no issues other than the shift light, and we drove it home. I'll call that a win. I'll work on whittling down the ET next year. I spoke with lots of people there that came up to me and complimented me on the car, which was nice. Good people out here in northeast Tennessee.
#23 ·
Just curious did you stall it up much on the starting line. I think you could get another tenth out of the 60 foot. the HP numbers you have from the dyno should be good for about an 11.90-12.00. dam respectable for a street car.
#27 ·
I think I may have found the down track repeating blinking issue with my Sniper shift light. It has a feature called Launch RPM. When setting up the shift light, I skipped over that feature in the menu because I didn't need it. Well, it comes with that feature enabled, and it is defaulted at 3,000 rpm. I should have disabled it, which I have now done.
