Anyone know how to lift a 80 pound head (even with 2 people standing on either side of the vehicle) on to a 235
engine block?
engine block?
We were able to remove the head, in my garage, with the hood in place. The manifold was unbolted and removed. When installing the manifold, care is needed to make sure the manifold gasket is properly aligned. It took a couple tries to get it correct.Wow-Thanks. Does the hood have to come off??
The intent of my approach is to leave the hood and everything else unrelated to the head in place.Wow-Thanks. Does the hood have to come off??
Thanks Bill.We were able to remove the head, in my garage, with the hood in place. The manifold was unbolted and removed. When installing the manifold, care is needed to make sure the manifold gasket is properly aligned. It took a couple tries to get it correct.
Really like the 2 x 4 handles suggested by stovebolt. We just muscled it out, and that wasn't the easiest to do.
Thanks, appreciate your advice.Hood can stay on. Like Ted noted, its awkward and a little unwieldy so take your time because as you have observed, that head is heavy. If you have the room, try making up a pair of guide pins out of some standard long bolts. Cut the head off and cut a slot in the top of the shaft to use a screwdriver or grind flats to use a small wrench to remove them when the head in in place. You don't want them too tall or you will have issues getting the head over them so just enough so they stick out of the head just a little.
These blocks do not have dowel pins in the block to locate the head and gasket and so its easy to get the gasket and head out of kilter when you are installing them so I use pins.
Good advice from the guy who knows more about these engines than anyone else here.Hood can stay on. Like Ted noted, its awkward and a little unwieldy so take your time because as you have observed, that head is heavy. If you have the room, try making up a pair of guide pins out of some standard long bolts. Cut the head off and cut a slot in the top of the shaft to use a screwdriver or grind flats to use a small wrench to remove them when the head in in place. You don't want them too tall or you will have issues getting the head over them so just enough so they stick out of the head just a little.
ThanksHow about one or two welded T-handles made to thread into rocker stand holes. did this on the 230 head, one T-handle that picked up on a central rocker stud. Different head but same idea.
