Very interesting idea. I assume the H-pattern is preserved with 1-2-3-4 and a longer pull back and up (or down?) engages reverse? One would have to be careful engaging 1 or 2 to assure the pull didn't go into the reverse lever. From your picture it looks like there are two standard shift levers for R, 3 and 4 with a straight shift lever for 1-2. Is that correct? You also say to narrow the key at the bottom of the shifter tube that engages into the 3 levers. Is that making it thinner widthwise, or shorter lengthwise?
You got me thinking... :hmmmm2:
The Key needs to be shortened lengthways [down the column length]
This is for the purpose of the middle lever only. So it doesn't move 2 levers together.
Last night I got thinking after my post about a reverse safety lockout.
You need to drill a hole in the outer column so a solenoid pin freely goes in it. [later a nut is welded on to screw it a lockout solenoid]
You put the gearlever into each gear one at a time [except reverse] .As you do this you run a drill through the outer tube drilling into the inner shifter tube.
You should have 4 x holes in the shifter tube.
Dismantle the column and cut the shifter tube from hole to hole making a square.
When reassembled with a solenoid pin in position the 4 gears can operate freely BUT you cannot pull back or push forward on the gear lever to get reverse because the solenoid pin prevents this.
The solenoid should be activated off the stoplights via a clutch pedal switch [in series]
And reverse gear should be "Forward and Down" beside 4th
[Top gear is the only gear you never use the brakes and clutch while shifting, whereas you do on other gears while downshifting into corners]
Done correctly ,the car would appear to be unmodified
