Hey guys,
I've been thread digging and can't find an "exact answer" for a problem that seems rather common. There is a thread that was close to what my issue is that is current but I digress. I have a 350 chevy, I can get it to fire up if I push in the pedal while I turn the key. If I try to fire it up without pushing the accelerator in it will crank but not turn over. The engine will not idle if I push the accelerator in to get it started and once I take my foot off the gas it will die. I replaced all of the rubber fuel lines as well as the fuel filter. I have never had this engine running as I traded for it from a local racer. I know the timing is not "right" as I did not set it. I am 99% sure it was at tdc before I got this far (removed plug 1 and turned it by hand until i felt air and the rotor was point at #1) It did backfire out of the carb (600cfm edelbrock) two times. Am I 180 out?
Would it run (even with pushing the accelerator in) if I was 180 out?
Also, I have a 1968 muncie trans and the hurst shifter is out of alignment. I tried the 1/4 drill bit trick but I still cannot get reverse!!
I also cannot get the bolt back into the neutral alignment hole (it won't thread back in) Does anyone have any pictures of how the rods are suppose to be and or any information for this problem as well? Thanks for all of your time and helpful suggestions
