Here we go. This should be fun. I'm having som gap issues that needs some smarter brains than mine to fix. First up, let's start with the driver door. I had to cut a body mount from the frame and adjust to get a descent door opening and closing but the door seems out of wack by the A pillar. Here is some pics:
As you can see the top of the door is really close to the A-pillar while the back of the door, at the B pillar has a great looking gap and is a tad shy a 3/16". The door is sitting a little high and needs lowered as well but I can't get the gap wider in the pic. It is paper thin close but not hitting. If I tilt the door back then my gaps at the sill and B pillar are wrong. This may have to stay like this till the next body working session.
Next is the driver door at the bottom near the fender:
You can see the door doesn't line up with the end of the rocker. I think this one is my fault as I built that corner from scratch. This will have to be addressed when I repaint.
Here is a shot at the driver door/fender/cowl. You can see the fender has dropped and the door is a tad high:
Sorry, it is a little fuzzy. I can't seem to space the fender at the cowl to raise the tip of the fender because the more I put spacers in the worse the cowl to fender gets.
Next lets look at the hood to cowl gap. This one, I'm at a loss to what the problem is. I'm out of adjustment on the hinges unless I am moving in the wrong direct. I got confused when looking at the bolts, like I was going the wrong way. Here is the gap:
The driver fender gap looks good here but if we move to the other side it gets really bad. See:
The hood sits up about an inch in this area, the door is hitting the fender and I can't slide the fender back any more towards the door to shrink the gap at the cowl and the hood to cowl gap is too wide:
It's a freaking night mare. I need some very serious help. I'm beating the heck out of the paint and not getting anywhere. I can't afford a professional so I need to figure this out myself with some help from you guys. So any help is appreciated.
Josh
Josh
