just wondering what everyones experience is for daily drivers and weekend warriors?
:bawling:....because its not mine."Production mass air sequential electronic fuel injection computer.
I wonder how he's getting sequential operation without a crank sensor??
Eight high quality fuel injectors, sized to your application. The injectors are sized to allow ample room for large increases in horsepower. These fuel injectors are held to much closer tolerance than typical production injectors.
Ya, right..Likely amounts to a set of flow matched injectors... NOTHING special about them.
All needed sensors. Most of the sensors are mounted right on the injection system for a simple install. No crank sensor to complicate the process!"
He has the MAF in the air cleaner...Great place to expose it to turbulent air flow and screw up it's ability to read consistently.
For that kind of green, it would be a much better deal to get a tuned port for the average engine.
As for this problem:
"The issue being when I would hit the throttle, it would take about 12 seconds to return to idle. Here is where another example of the owner comes in....he said I was just exaggerating the 12 seconds and it was normal for it to take 6 - 8 seconds. What normal EFI setup takes 6 - 8 seconds? "
If there's a throttle cracker/follower adjustment, that issue could be tuned out. [He states it's a production ecm.] Does the sytem have an IAC idle control?
Want a REAL dual quad EFI system?? Here ya go: The engine in my 6T5 Belve/HEMI car. Yep, it's home built.....:sign0020:
That's what I would do. I sure like that one from Affordable Fuel Injection. They even custom program it to your engine and cam for no extra charge.For that kind of green, it would be a much better deal to get a tuned port for the average engine.
