I feel I should know this, but I want to make sure I avoid ground problems later. I'm guessing to the intake and then a jumper to the body (firewall)? Thanks for any imput.
My battery is located in the trunk...So, I ground it to the frame and body back there...Then run a ground to the frame to the engine up front.I ground the heck out of everything on my cars. I run from battery to block, then another equal size cable from block to frame, and a smaller braided cable from frame to body. I've never had an issue caused by a bad ground on my builds.
Adding to the above, I think I do have one ground in series. If so it's from the firewall lug to the frame. There is no real reason to ground the frame if other things are wired factory style, but I believe my electric fuel pump negative goes to the frame. It might work without the extra frame ground, because the bumper bolts provide a pathway for the negative to the frame.I have 2 at the battery, the heavy one to the block, and the 10 or 12 gauge to the body. I don't like the idea of jumpering the grounds in series.
Thats how I did mine but also added a 4-gauge ground wire from frame to body for all the other circuits.My battery is located in the trunk...So, I ground it to the frame and body back there...Then run a ground to the frame to the engine up front.
All my hotrods have the battery in the trunk, so that's why I also use the frame to battery and frame to engine, but also frame or engine to body with a braided strap too.My battery is located in the trunk...So, I ground it to the frame and body back there...Then run a ground to the frame to the engine up front.
For my 1957, I went Battery to Block. Then, Block to Fire Wall. Firewall, behind Ballast Resistor. Driver's side of Firewall. Closer to the Fuse Block/Dash/Instrument Panel, on Interior side of Fire Wall. I made a small Bare Metal spot. Ran 10 Ga wire. Block to Firewall. ENCAPSULATED it, with Black Liquid Tape. Where did Chevrolet put Factory Braided Copper Shunts? TWO, back of Block to Firewall? YUP! Those disappeared many engine swaps ago! LOL! I had also Replaced Fuel Tank/Sending Unit. Ran 12ga. ground, from sending unit to Bare Metal spot on Frame. Stainless Steel Self Tapping Screw, into Frame Rail. Liquid Tape again. Encapsulated it. WOW! All my Fuel Gauge problems Disappeared. Car Cranked FANTASTIC! Dash Lights Brighter, Blinkers, improved etc.I feel I should know this, but I want to make sure I avoid ground problems later. I'm guessing to the intake and then a jumper to the body (firewall)? Thanks for any imput.
