Blower under the hood on BBC?
8.3K views 9 replies 9 participants last post by  Mcsful8er
#1 ·
I've got a BBC with Earle Williams mounts, 3/4" forward. The car has power steering and will have A/C. I have a PRC radiator with electric puller fans.
My original plan was to add a ProCharger but haven't seen any installed along with A/C and PS in a BBC '55, and have decided I'd prefer a less complex installation than I think this will require.
Before I give up on supercharging, I want to check one more path. Do any of you run a smaller roots-type blower on a BBC that tucks completely under the hood of your '55/'56? If you've gotten that far, how about room for PS and A/C?
Thanks!
Jay
#5 ·
Anybody have any idea who's 55 or 56 chevy this is? It popped up on the Car Craft facebook page and i can't any more info. I'm working on a similiar set up with side draft webers for my 56. My big block is lowered to about the same height as this one.
Any info would be great, I just want to find more photos.
#6 ·
Have a magna supercharger on my Corvette. Sits pretty low. Might check their website for dimensions. I would think procharger would have the pulleys to add their unit to just about any application. Did you call them? That is a lot cheaper that a supercharger. I think mine ran $6-7000 for the Corvette. It is inner cooled with electric water pump, radiator, etc.
Attached is a pic.
http://www.trifive.com/forums/attachment.php?attachmentid=63591&stc=1&d=1349818235
#9 · (Edited)
There are several guys here on Trifive that have small blocks and the small blowers under the hood.
The 55/56 has more room under the hood than a 57.
It will be close and probably depend on the air cleaner you run.
My 57 BB with small blower will not fit under the hood.
The carburetor is above the hood about one inch without air cleaner.
Also with any blower you need to think about the size of the air cleaner.
http://www.secondstrike.com/Technical/AirCleanerHelp.pdf
http://www.secondstrike.com/Technical/AirCleanerCalc.asp
