break in oil
1 reading
8.7K views 35 replies 19 participants last post by  upsrod
#1 ·
How long should keep brake in oil after building engine with new cam. Raybob
#2 ·
with a flat tappet cam I would change the oil at 100 miles and use brake in oil on that oil change. next go 500 miles then change to what ever you want to use with a zddp addative.
#3 ·
Okay....I'll ask the dumb question....What is "break-in oil" ?
#6 ·
Okay....Got it...Thanks
I used Valvoline VR-1 high zinc racing oil to break-in my roller cammed ZZ4....I use it in my flat tappet 265 at every oil change as well.
#7 ·
any new engine will shed some metal no matter how well it's built on initial start up & run cycle the high zinc minimize the initial wear on everything definitely more critical with flat tappet cams than roller engines & zinc additives should be added to any oil not especially blended for flat tappet equipped engines at every oil change such as mentioned Valvoline vr1 racing oil
#8 ·
Back in the day we used 30W non detergent oil for break in to seat the rings.Used to buy it buy the case ( a case then was 24 cans ) and used a pint of STP oil treatment mixed with a pint of the same oil for assembly. Used it on every thing but the rings and soaked the lifters in the other pint of oil left over. Never had a problem with oil consumption or camshaft and lifter wear. I guess even the N/D oil was full of Zinc.
#13 ·
THE very best break in lube to me is still GM engine oil supplement (EOS). I have to be careful to find and buy the old formula that isn’t made anymore. I used to find some every once in a while at swap meets. I have many cans now, so I quit hunting, Don’t think I have enough time left to build and fire up that many new engines. LOL
#15 ·
Old formula GM EOS was a really good product but no longer made (EOS is still available but not the old formula). it turns up on ebay every once in a while but dear god when it does, you would think they were selling Roman gold pieces. Flat tappet cams, and high spring pressures are hard on a cam so a good break in oil I think is essential to having the best chance of breaking in a motor without wiping a cam lobe or two. Joe Gibbs-Driven sells a version, although I have never used it myself. I do use the Driven GL-4 gear oil in the muncie and it works well. Brad-Penn (now Penn Grade One) sells a pretty good version of break in oil. That one I have used with a couple of motors with flat tappet cams, spring pressures anywhere from 270 through 300 lbs open, and every motor I used it on broke in just fine and no issues. I ran the break in oil for 100 miles, changed it and ran the regular Brad-Penn 10-30 high zinc.
Truth be told, there are other brands that probably work fine, I just dont want to tempt fate given the success I have had with the Brad Penn.
#16 ·
It also depends on the cam specs. A cam with huge lobes needs the zinc at all times, A small stock type cam doesn’t need it much. I have a flat tappet in my old Crummy truck. 0ver 300k on it and all I run is off the shelf oil with zero additives from me. Any and all hotrod engines of mine get EOS added at oil change time though. At first-fire break in it goes without saying that the motor isn’t turned without EOS in it first.
#18 ·
In the late sixties early seventies GM had major issues with camshafts having a lobe or several go flat along with valve guides wearing out & they had 5year 50,000 mile warranty so as a line tech I replaced many cams & lifters along with pulling heads to have valve guides replaced if there wasn't a can of GM EOS charged out on every repair order with either of those repairs warranty was denied great stuff at least the old formula was new Short & long blocks came with EOS well up into the late nineties anyway
#21 ·
Not trying to steal the thread but on a somewhat related topic . I bought a GM #366250 454 LS6 solid lifter crate engine many years ago for my 56 , I think It was the late 1990's right before the 502 came out , and am just getting ready to light It off for the first time . It came with oil In It . Anyone know If GM put break In oil In this crate engine back then by any chance ? If not , Is a good supplement such as EOS added to the oil sufficient or Is It necessary to add a full crankcase of break in oil ?
#22 ·
Main question i'd have would be sitting all this time would it have formed any moisture in the oil maybe not Just thinking if you don't drain the oil & refill with something like Joe Gibbs Driven or equivalent then i'd for sure add a zinc additive plus i'd use a priming tool to circulate oil before cranking & turn over several times by hand
#24 ·
I drained the oil out years ago and have It In 2 plastic jugs because It came with a deep sump 8 or 9 qt. pan which I obviously could not run on my 56 . I was thinking about putting the original oil back In and adding a good supplement , and yes of course priming It good . So the question Is , Is It better to run ALL break In oil , or Is adding a good additive sufficient ? It has a pretty high lift mechanical cam and I don't want to hurt It . I used EOS many times working at a GM dealership also , to me It seemed very similar to STP .
#26 ·
I'd guess the oil probably is still good if that's the case might have been even had it still been in the motor the oil pan is it the type that looked like it had a lower section welded on the reason I ask is way back when I ran a 55 B modified late sixties I used a factory L88 oil pan it fit perfectly although may not have on a lowered car back then everything was shove a set of 409 station wagon springs in the front & add leaves to the rear till is set level
