One of my friends says he saw the numbers in one of his books.I never saw it in any of my books.Is it true?
Same as 305 vs 350 crank, the 4 bolt factory 327 is urban lengend.I think you'd have to add a ton of weight to a 307 crank to balance it to 327 spec's with the bore difference. BTW I have a fresh ground (10 YEARS AGO NEVER INSTALLED) 10-10 327 forged Large Journal in the garage somewhere.
Which would mean there was a large journal 327 steel crank? Or, did the 68 corvette use the small journal blocks still and the "run of the mill" 327 used the large journal because of the transition to 350???1968 CORVETTE HT coded L79 327 had 350 horsepower, HP, HO, HE, coded Base 327 had 300 HP, Corvette did NOT get the 350 'till '69.
327 large journal motors were used in calender year '68 in '69 Camaro's, Jan '69 went to the 307 as the base engine.
And as to crankshaft lore, 396 and 427 cranks are interchangable, IF you use a lightweight forged 427 racing piston with the 396 crank. The counterweights are different thicknesses, the 396 being smaller/thinner.
