Engine choice..
4.1K views 7 replies 4 participants last post by  BO185
#1 ·
General consensus?
L33 alum block advertised as a "Hipo".
LC9 " ". May have DOD, VVT, depending on the yr. Neither of which, do I want.
Both have about the same miles.
Base FWHP is not an issue, as a cam is going in, along w/ an intake, headers, a tune, and, maybe a small shot.
The L33 is a 2005, and should have the better rods, floating pins.
The LC9, several of which are available, are newer, as in the 09/10 yrs.
Price is not a big difference.
Coin toss time?
#3 ·
Yep,,
Cam/lifters, rocker bushings.
The DOD engines have a different oil pump in them, and a different valley cover.
I usually use a LS6 cover, and a aftermkt pcv.
Additionally, I use a Melling oil pump.
Will also get an LS6 intake.
I may just go w/ the L33. About $2000, free frt.
#4 ·
The L33 HP rating was due to it using 799/243 style heads. GM used flat top to get CR back to were they were with the smaller chamber heads. It alsi uses the LS2/LQ9 stye floating rods.
All 2011-14 truck motors are VVT.
The Gen IV LC9 5.3L is same 799/243 heads and has flat tops as the Gen III L33, but has a larger TB on the intake.
To delete the AFM you have to remove the heads if its an AFM motor. You have to change the 8 AFM lifters, AFM lifter tray, and valley cover to a non afm style. Oil pump will work with either fine. AFM is more flow than non unit.
I would do the L33. Same motor as the Gen IV and your swaping to LS6 intake anyway. No AFM or VVT to worry about.
#7 ·
Ebay..
Just search for, in my case, Lc9, or L33. [Or, any other engine code, you want].
Many are free frt, 3 to 6 mo's warranty.
We've done this before, and got 1 less than great engine. We called, and they sent another, and told us to keep the first one...
100K on these engines is not a lot of miles.
Make sure you get all the "trimmings", such as harness, ecm, pedal, etc. Buying the accessories ala cart, is expensive.
#8 ·
www.car-part.com You can search local yards and call. Use 2000-2006 for Gen III motors and 2007-up for Gen IV. Use either 1500 or 2500hd. RPO code ID's are in the FAQ sticky in a link listing what each code is and year. Tell them you want a complete change over engine with everything and uncut harness.
