*engine id
1K views 6 replies 5 participants last post by  classic gary
#1 ·
I have a 57 engine number i cannot find code info on.
19W352927 V1108DC
Anyone know what I have or where i can go to find out?
#2 · (Edited)
What you have is NOT a 57 engine. It is a much newer engine. The only DC suffix I found with a quick search is a 69 307.
DC 1969 307 Powerglide - 200 - F X A
Just found this one also, 67 283.
DC 1967 283 195 2 m/t, Low Compression
You will need to get the casting number off the block to see exactly what you have. It is on the block behind the drivers side cylinder head.
#7 ·
First question to ask: does the block have the bosses for side motor mounts.
Then, ask for the casting number and casting date. Then there are no secrets.
