First Gen SBC hearders and Vortec heads
12K views 5 replies 4 participants last post by  Busted_Knuckles
#1 ·
Ok I know this question has probably been asked before but I couldn't find it so here goes. I will be using Vortec heads on my engine project for my Nomad why you ask, because I got a killer deal on a Barry Grant Six shooter set up and I've always been a nut for Tri-power set ups. So that being said I will most likely go with a nice set of after market aluminum heads I know they will fit on a first generation block which will allow me to utilize the stock front motor mounts and bell housing mounts etc. I have a brand new still in the box pair of stainless steel block hugger headers for a first generation sbc.
So I owuld really like to be able to use them if possible. if need be I guess I could replace the flanges with Vortec one's but I owuld really hate to have to do that. I know a lot recommend side mounts but I like to use the block hugger style headers as the front of the car will be pretty low and I am concerned with clearance issue running conventional long tube headers.
#6 ·
snaptwo thanks for the info but I am going to run the block hugger headers I got from Speedway, the 57 I saw last night at a local car show is running them on an LS1. I've seen the car around now for 4 or 5 years and noticed that it's a first class resto mod but last night was the first time I payed close attention to what exhaust he was running. I can't attest to whose valve covers he's running just chrome stamped steel but he looks like he has plenty of clearance. I can send you a pic or post it in my garage if you like
#5 ·
Just a word of caution on the ramhorn on vortec heads , I did a quick measurement on the center plugs of an old #882 --4 1/4" cl to cl., vortecs measured 4" cl to cl. , end ports were fine . The ramhorns I got from the Jeg boys are 2.5 outlet , like the old vette ones. They are veerry close to the valve cover/flange/ gasket surface. Someone mentioned doubling the ex. gaskets and grinding a relief in the manifold itself. I do have a friend that is bringing over a pair of genuine 2.5" ramhorns just to see if these knockoffs are fairly close as some of the finish machine work is a bit suspect.
#3 ·
Watch clearance of header tubes to spark plugs. Spark plug locations moved slightly with Vortec heads. When I was looking for headers about a year ago, the only mfg. that stated their headers would fit were Heddman. Sanderson said definately not, the others didn't really know. Doug's said yes but a little over my budget.
You might want to pull up a detailed spec sheet to see the spark plug changes and double check.
Good luck
#2 ·
standard sbc headers work fine on vortec heads. I have done this on customers cars very often.
#4 ·
Well hotrod726 you made my day, these are from Speedway motors whose tech department was closed so they couldn't give me an answer but we just returned form a local car show where I saw a 57 with an LS1 that I've seen there several times and he was running rams horn manifolds his buddy said he was building a 57 using the same combinations I was mentioning except the intake set up and he's using block hugger headers as well.
