21 - 40 of 73 Posts
And likely the longer a shackle is, the more it can deflect. Shorter is better to control side deflection.
It was before this topic, but recently there was a post with a pocket kit spring touching the frame, and boy did it look like it had long shackles! It made me think of this right away just looking at the pic.
My point was that the video didn't demonstrate anything one way or the other.
You didn't look closely, watch the rear end movement in the first one vice the tires taking the load and moving in the second.
As a "no kidding " person that runs road courses, I can tell you that "yes" there is a difference in adding a Watts or delrin type bushings on leafs. The video is a before and after and the difference are very obvious if you look in the right areas.
Discussion starter · #34 ·
So why have one if there's no traction loss without it?
As I stated this is to allow me to run wider rubber and not suffer any rub under moderate cornering.
Put aluminum bushings in the leaf spring eyes and put greasable spring pins in and you will see that side to side sway go away
I understand there is deflection from the bushings, however the spring itself by its very design allows a sizable amount of lateral deflection. Enough to require larger clearances then I want to have.
One thing to keep in mind with a panhard bar is they do also have deflection. It's a symptom of the design, as with fixed points at each end the panhard bar travels in an arc as the axle moves up and down. So it's pushing and pulling the axle left and right under compression/decompression.
How much it moves depends on the angle of the panhard bar, and length of travel of the suspension. But you will still get side deflection, regardless.
I don’t see what the big deal is. Since the axle moves back and forth from side to side during cornering what difference is it going to make that a pan hard bar moves in an arc? Yeah it would be better to have a Watts or triangulated, but a panhard bar will keep things fairly well centered during normal driving, and on a budget build will be fine.
Local machine shop
What would be the specs of machining something like this? I mean, inner and outer diameter as well as length?
My pop has a Bridgeport lathe and mill in his garage!
If other fellas might be interested, I could probably have him make a run of a dozen sets or so out of aluminum or delrin. Steel is a b*itch to machine so I know he'll want to do it in aluminum or delrin if possible.
21 - 40 of 73 Posts
