41 - 60 of 73 Posts
I don’t see what the big deal is. Since the axle moves back and forth from side to side during cornering what difference is it going to make that a pan hard bar moves in an arc? Yeah it would be better to have a Watts or triangulated, but a panhard bar will keep things fairly well centered during normal driving, and on a budget build will be fine.
I agree...and this fellow seems to know what he's talking about (not a tri-five, but still a leaf spring rear end car):
What would be the specs of machining something like this? I mean, inner and outer diameter as well as length?
My pop has a Bridgeport lathe and mill in his garage!
If other fellas might be interested, I could probably have him make a run of a dozen sets or so out of aluminum or delrin. Steel is a b*itch to machine so I know he'll want to do it in aluminum or delrin if possible.
Panhard bars are easy to make, a Watts takes som fabrication but IMO is a better system for leafs.
If you're talking machining aluminum bushings for the front control arms, then it would be ID and OD, plus a lip to keep them from moving once pressed into the control arm. Additionally you wouldn't want the control arm shaft to run directly on the aluminum, so each pf the 8 bushings would also need to be bored to accept a steel or bronze sleeve that the shafts would ride on.
So not just a simple case of making up 8 bushings to fit the control arms. Might save some time/work if you could buy bronze or steel sleeves the correct ID to fit the shafts, and then simply bore the aluminum bushings to accept that sleeve.
I just sent a link for a universal panhard kit.
Take a set of calipers and measure out the ID of your spring eye & the width of your spring pocket. And then you will just bore it for whatever diameter bolt do you use most likely half-inch.
Thanks Darren...yes, I was talking about rear spring eyes. I think the pocket is 2.58" wide (at least, according to this diagram it is: https://www.trifive.com/d1/garage/55 Chevy Assembly Manual/2-12.gif). That would probably be pretty easy to make.
Might see if I can make a greasable delrin one with a steel sleeve inside.
And finally as an option
But if it were me I'd just call these guys...they pick up the phone
Check this out
Check this out
For some reason I thought those were just for the shackles at first. Might take a look at them.
I doubt the addition of those alone would keep the rear end from moving side to side though. I have about a 3/8 inch on both sides in the rear...rubs in corners, and not even fast ones.
It will help, use beefy shackles too. A Watts or panhard is probably still needed. I sent you DYI kit links from speedway.
I'm a suspension guy, mostly street and track.
If you make your own bushings, make sure that tightening the through bolt doesn't bind up the sides of the bushing. To do that, the sleeve needs to be slightly longer than the bushing and be hard enough not to crush, or you need to use a shoulder bolt, the shoulder being just longer than the sleeve.
Of course, any that you buy should be that way too.
When I was building my Falcon gasser I couldn't find the Delrin or poly bushings to buy, but I thought maybe I could buy an existing set for another vehicle and turn them down.
I took a chance on a set for a late model Blazer, since the year I bought had bushings long enough, and large enough to work with. I took the sleeves out and put a threaded rod through the middle of each bushing prior to turning them down in my lathe. I turned the OD down first, and then used a parting tool to cut them to length. Once I had all my leaf spring bushings made for front and rear spring eyes, I turned the sleeves to slightly longer, and pushed them back into the reworked bushings.
The whole set for the Blazer cost me $59, and I actually had some extras leftover that I've used for various things since like radiator isolation pads, etc. It was cheap, and fun to make too.
I always prefer to have a small diameter hole in the spring I and use a needlepoint adapter on my grease gun for shooting grease into there and a greasable spring pin. I prefer aluminum bushings on everything on my cars though. I want them as tight as possible.
Poly doesn't belong on moving parts, Delrin or Aluminum is the way to go, otherwise stay with OEM rubber.
41 - 60 of 73 Posts
