Thanks Dennis, that motor has been a real labor of love for me over the past 28 years, no one other than my son (who just turned 18) has ever laid a wrench on it. I've been through it 4 times now in that time frame. Being a poor boy, one thing i did that may help other Rat Rodders was the method I used to balance the engine. When I lived in OKC 20 years ago, a friend of mine knew a guy who worked at a jet engine turbine shop. I tore the motor down and took the crank, harmonic balancer and flywheel, (same ones still in the motor to this day) down to him and he balanced everything on his turbine balancing machine. Not sure what it would cost today, but I gave him $100 bucks back then. I also found a real sinsitive scale and we balaced all the connecting rods to within a 1/2 gram. Balancing those components is really all that's important to the street rod guy (blueprinting is only for the guy on the circuit) and not necessary for a street car (not like we're going to be tearing it down everyother day ya know). I can tell you I know it's balanced well, back in the 90's when I was running Nitrous threw this engine, I had a muncie 4spd with a sloppy shifter and occassionally missed 2nd as I was power shifting with my finger on the Nitrous button....(yikes) and when you see that Tachometer needle dancing off the high limit peg for a few seconds, you know you've had one serious over-rev, but it was only because of this BB being balanced, it never came apart, And when I finally got my lead foot off the accelerator, it would come back down and idle like a kitten, (ye-ha) yep sure thought I was going to be picking up pieces more than a couple times, but this was actually R&D testing I was doing back then (I just didn't know it - ha) I proved the "poor boy" balancing method does work... okay, enough of that, but thanks for the compliment, i appreciate it. later on
