Radiator Hose Guide
1 reading
18K views 25 replies 14 participants last post by  Time4aroadtripp
#1 ·
Locating radiator hoses for an engine swap can be a bit of a challenge. Looking through the hoses in the back room of the local auto parts store is one way to do it, but anyone that has tried it knows it can be difficult.
I came across this Gates radiator hose guide (with pictures) and found it very helpful. It's a large file so it may take a while to download if you have a slow internet connection. The hoses are listed by size and most of our cars use 1-1/2 inch upper hose and 1-3/4 inch lower hose. Hopefully you will find it useful.
Gates Radiator Hose Guide.pdf
I used this guide when looking for a lower radiator hose for a 1956 Chevy with a BBC swap. The engine is mounted 3/4 of an inch forward, with a 6 cylinder radiator, and a short water pump.
I ordered two 1-3/4 inch diameter hoses that looked like they could work. Both hoses will indeed work but one of them fit perfectly without any cutting. This sure beats hanging out in the back room of the auto parts store.
Discussion starter · #14 ·
The 20242 is too short for a V8 with the radiator in the 6 cylinder position.
I would try a Gates 20145 or a 20345. Both of these hoses are 1.75 inches inside diameter on both ends. The 20145 is 16.4 inches long and the 20345 is 18.7 inches long and will probably need to be cut to fit. I can not guarantee these hoses will fit as I haven't tried them myself, but I think one of them might work in your application.
Discussion starter · #18 ·
Since I expressed some reservation with the Gates 20345 lower hose I installed in a post above I thought I'd take a look at the 20475...since I was going to town and Oreilly's showed one in stock. It looks more or less like most lower hoses I've used over the years. Comparing the two on the bench - the 20475 (on left) looked like it should fit but perhaps wasn't not quite long enough next to the 20345 that I had already shortened and installed:
Again - I have a Gen 1 SBC mounted 3/4" forward with a radiator in the 6 cyl position. The 20475 did indeed fit - it was just long enough since the right-angle configuration allowed for enough 'give' to reach both the water pump outlet and the radiator inlet. My concern with the 20345 is that because it lacks that right angle I was used to seeing, the tube heads straight toward the radiator inlet at a downward angle that straightens out just at the inlet. What I hadn't realized until I tried the 20475 is that it has the benefit of extra clearance for the (in my case) fuel pump clearance:
Because of that angle and how far it takes the hose toward the right of the pump, which is probably beneficial in some instances (like accessory drives on the RH side of the engine), the back side of the hose gets pretty close to where I have the fuel pump outlet (intentionally configured for the placement of the inlet), and limiting routing choices of the pressure hose to the regulator. So for me, I went back to the 20345 which seems to fit well enough and gives plenty of fuel line access:
Another comparison I thought interesting - cost. When I found the 20475 in stock locally I was a little surprised at the price - $36.99! Others in this discussion: 20345 - $21.99, 20145 - $33.99, 20505 - $33.35, 20424 - $33.99. Of course these are local store prices - if you have a part number in hand it's obviously better to shop around. For example a quick check on RockAuto shows prices less than half of the above. I've had the 20345 in my extra parts stash so it was 'free' to me.
Researching radiator hoses was something I really couldn't do until I put the front clip back on the car. I had read several threads looking to find possible part numbers and info, a resource of this forum I greatly appreciate. And as has already been pointed out it's just not as easy as it once was to go the back wall at the local parts store and pick out a half dozen hoses to take home and try out. Hope this info helps someone in this same search down the road.
This is some good information. This narrows down the choices of what lower hoses might work on cars modified from stock.
