Rocker panel prep (lots of questions)
5.2K views 3 replies 4 participants last post by  Chevynut
#1 ·
Well, I'm working on the world record for time spent getting these rockers replaced. I got the outer rocker out completely and 95% of the inner rocker. The new pieces are about ready to go in but I have several questions...
1) I used W&G remover to clean up the new inner and outer rockers. I'd use a fresh towel until they wiped clean. Seemed to work good but there were some stubborn spots so I sprayed a little Goo Gone on it and it did a great job on those spots but revealed that the new pieces were still filthy. I wiped down the entire inner and outer rockers with goo gone and these pieces were nowhere near clean. I followed up with w&G remover to clean up any possible residue from the goo gone? Will the goo gone cause any problems down the road with adhesion? Could I have used lacquer thinner and done just as good a job? I have a 5 gal bucket of lacquer thinner and just a spray can of the goo gone. :)
2) after the pieces were cleaned up, I scrubbed them with a red scotchbrite pad. It doesn't leave much of a scratch on the pieces. Am I alright or should I use a heavier grit sandpaper until I see defined swirl marks?
3) The dog legs are somewhat pitted. I'm hoping I can still plug weld them to teh new rockers and fill with metal 2 metal. Did you prime the underside of the dog legs or leave them alone?
4) Any problem with brushing on epoxy primer on the insides of the new rockers and dog legs? My compressor isn't set up yet for spraying and I don't want to put it off until it is ready.
5) On the edges of the outer rocker and parts of the inner rocker that are going to be plug welded, is it alright to just spray a coat of weldable primer on there and be done wiht it?
6) sorry, last question: the rear floor brace that welds to the rear part of the inner rocker is inaccessible unless I cut away the quarter panel, correct? I have the quarter disconnected from the inner rocker so it's just hanging there but not sure that I want to pull it back so I can reach tools in there to remove the last part of the old inner rocker. How do you get to this and how do you weld it back to the brace when it goes back togethere with the quarter in the way?
Jeff
#2 ·
I would suggest cleaning it with just plain old mineral spirits, then rinse with a jug of rubbing alcohol. I would scuff it with 400 grit paper afterwards. After that, you could spray the inside with a self-etching primer and spray the edges with weld-through primer. There is a way to spray the insides with a rust-proofer after they are installed by using a spray tube through the holes. You can brush the primer, that is fine. As for the dog legs, prime EVERYTHING that you can. Paint it if possible with some rattle can paint as well.
#3 ·
The weld thru primer on the inner and outer rocker edges will be fine. You can also epoxy prime these edges along with the inside of the rockers and when the epoxy primer is dry, you can grind away the primer where you will be making your plug welds. I took a piece of thin cardboard and cut a 3/4" circle in it to use as spray painting mask. I held this mask over the area where the primer was ground away and sprayed weld thru primer on those spots. This way gives the areas that aren't being welded the protection of the epoxy primer and the welded areas will also be protected by the weld thru primer. Just remember to scrape away the weld thru primer through the plug weld holes before you weld. Use a scribe or a small screw driver with the blade filed to a sharp edge to remove the primer, welding is easier and cleaner when you start on bare metal.
The inner rocker can be removed from the rear brace without taking the quarter off. You will have to drill out the spot welds from underneath the car that hold the inner rocker to the brace. You may have to use an angle drill for this. Clean off any dirt or undercoating on the flanges of the brace, take some sandpaper and lightly sand the vertical and lower flanges. This will help you see where the spot welds are, they can be hard to locate. There should be two spot welds on the vertical flanges and two or more on the lower flange. There is also a small flange at the very back of the inner rocker that is bent in towards the inside of the car that is spot welded on. You may be able to drill these out from inside the fender well.
I know how you feel about taking so long to do this job, I have replaced the inner and outer rockers on the driver and passenger sides. It took a long time , removing the old parts was the hardest thing to do. It wasn't easy but the finished product turned out real nice. Be patient and keep asking questions here and your results will fine. Good luck.
#4 ·
1) Could I have used lacquer thinner and done just as good a job?
Lacquer thinner does a great job of removing the bulk of the stuff that they put on the panels to keep them from rusting. I cleaned all my sheetmetal with lacquer thinnner, first wiping it down with a rag, then spraying it with a cleaning gun.
After that, I cleaned again with an oil and wax remover from PPG, DX330, followed by DX579 metal prep or Metal Ready applied with a scotchbrite pad. Then it's ready to shoot epoxy primer. I also used 3M weld-through primer along the plug welded edges.
