Should my 350 sbc have a coolant bypass hose?
7.1K views 3 replies 4 participants last post by  Rick_L
#1 · (Edited)
A member’s earlier post got me wondering …
Have a ’75 350 small block.
No heater or heater hoses.
Has a half-inch plug in the top of the water pump.
Has a half-inch plug in a hole just to the driver side of the water neck on an older Edelbrock manifold.
Did not have a thermostat when I got it. Put in a 160-deg thermostat. Did not drill it.
At start up consistently goes to 190, then drops back to 160 when the stat opens. (On a warm to hot day it can creep back up to 190 ..in traffic. But o.k. for how I drive it …no parades).
Would a by-pass hose between the two half-inch holes make any kind of difference? Drill the thermostat? Run without one? Leave as-is? (I say 1/2 inch on the holes ..just guessing, probably bigger)
#2 ·
IMO, I Don't think it will change a whole lot. 190 when hot is still 30 degrees or more away from trouble. I have in the past turned on the heater fan and disipated heat through the heater box but on a warm day that makes the interior of the car "toasty". I think you are good the way you are.
DB
#3 ·
A 1/8" hole in the thermostat will make the 190-160 swing smaller but other than that there is no need for anything else.
