Ok, still getting Dads 57 nomad ready for my wedding day and the oem drum brakes pull really bad to the right.
I tried adjusting the star adjusters so there was just a little drag on each wheel with no better result
Tonight we jacked up the front end and spun each tire and then hit the brakes the right locks right away and the left you could turn by hand so we bleed the left one and it got allot better but after a run down the road it still does the same thing.
Ideas? Bleed the whole system or keep adjusting the front adjusters?
Now the steering has about 4" of play in the wheel and from what I could see its mostly coming from the pitman arm connection at the control rod. Maybe a little bit on the idler arm but not too bad.
I know nothing about all the springs and ball style setup on this so any help would be great. I did a frame off myself on my 69 vette so I just need some direction on this older setup and what tends to be the problems.
Does it need adjustment or a new spring and guts? Or does that ball end on the pitman wear out allot?
We are looking for a fix for now as Dad does not want it all torn apart right now or as he says "when its yours you can do what you want to it"
Thanks for all the help so far guys:cool0012:
